Results 1 to 20 of 20
Thread: Help Me Solve My Tranny Problem. PLEASE!
    has a big dent :( c0l7hy's Avatar
    65 south
    Default Help Me Solve My Tranny Problem. PLEASE!
    a couple of weeks ago i was leaving a friends house. i had to turn around in the street so i was pulling a three point turn. when foward fine, then reversed fine, then as i started to slip the clutch to go foward again. i heard somethin break and my car was just reving but wouldnt move. i could put it in gear, and i probably shouldnt have done this but i even put it in gear with out depressing the clutch pedal and it went into gear just fine, with no grinds or anything. but as i reved it wouldnt move. i dropped my transmission and my clutch/pressure plate are both fine. the throwout bearing seems fine as well. im guessing it is something inside the transmission? when i turn the input shaft the places where the axles would be going into the transmission turn at the same speed no matter what gear i put it in. anyone have any idea what is wrong? thanks
    edit* car is integra type r, b18c5
    info about the car make model trim
    Don Mon SiRed94's Avatar
    Morrow 30260
    are you sure it isn't an axle issue?
    Hrmm, my car did the exact same thing when my clutch went out (wouldn't move & would go into gear w/out even pressing clutch); the splines in the disc were rounded out. But yeah I would've thought it would be either a clutch issue or axle .. So I don't know how to help you homie.
    02 WRX patrick4588's Avatar
    warner robins
    axle may have broke in the boot or separated the joint. check your axles out
    GCO Member
    NRA Member
    x2. my guess.
    N/A POWAH! Gorilla Eg!'s Avatar
    I cant be of any help on this topic.....but ill bump it so maybe someone else will!
    You need to start checking out the drivetrain. If you would have told us your car that would have been a major help.
    Crash
    Snellville, GA
    what kinda car is it? need info if you want help
    1993 Honda Civic EX
    1993 Acura Integra
    1998 DB7 Integra
    1989 Toyota Supra
    1993 Toyota Supra
    Marietta, GA
    yep... i'd check the axles first while you have them out, if that's not the problem and you know the clutch is ok, then i'd say time to open up the tranny....
    Aug 2009
    i had this problem in a friends h22 teg. the axle came loose. i can put it in gear with out pressing the clutch down also. then we checked the axle and that was the problem
    axles!
    i brke axles launching from a dig lol, snapped inside the cv boot, would go into gear just fine just wouldnt move.
    known as Charles
    Sounds like an axle problem but I assume you checked them before you pulled the tranny. I think it is prob a diff problem. With no load on the tranny you can turn the input shaft and the diff will spin. You need to put the axles back in the tranny and have someone hold them while you turn the input shaft (make sure it is in a gear). This will let you know if it is the diff or not. If you open the tranny you may not see any problems if it is in the diff. Good luck.
    Main Stream Performance
    www.mainstreamperformance.com
    MSSracing.com
    man, you pulled your tranny out once and brought it to me, I remember it was perfect inside, suck if the diff went.
    Where Am I
    Anybody realize that this is over a year old???
    Quote Originally Posted by Turbodude06 View Post
    i was looking at it and was thinking when the fuck did i post on this. saw the date then lol at austin bumping old as shit posts.
    oh shit.
    lol, yr old thread. OP has most likely moved on...
    yay old post.... well based on the title of the post... "Help Me Solve My Tranny Problem. PLEASE!", my advice to the OP is.... stop dating chicks with dicks and you will have no tranny problems.
