Results 1 to 11 of 11
Thread: vavle cover gasket
    Columbus
    Default vavle cover gasket
    i was replacing my valve cover gasket. did it just yesterday, torqued it down right, no problem. painted a dif valve cover to put on it. replaced that today, don't know y i didnt wait, and was torquen it down and one of the bolts broke. any ideas how to fix????
    B20 wat u want to do JDMB20's Avatar
    Macon
    drill and tap
    or if ther is enough tip left on it you can try and back it out
    ONE DAY
    Columbus
    wuz told if i could get it outa the head, i could go to honda a buy a replacement bolt. wuts the torque spec for it to the head? if anyone knows
    Macon
    ya you can go to honda and get a new bolt but first get it out of the head....... i just hand tighten them down and have never had a problem
    ONE DAY
    Columbus
    aight, appreciate it man.
    hand tight all day
    just take the valve cover off, it's a 10mm, use a wrench or deep socket 6 point to take it off. No need to tap or drill.
    Marietta, GA
    Quote Originally Posted by mp82
    I think this guy was talking about the valve cover studs that screw into the top of the head with 10mm nuts welded to them, then the valve cover nuts screw onto the studs... but anyway if the stud is broken off at the head, get a thread tap kit and go to work. either that or find that easy out drill tool that Billy Mayes always talks about on the infomercials. good luck.
    Macon
    ummmmmmmm..... he broke it so whers is the 10mm 6 piont at (NOT THERE)
    ONE DAY
    Columbus
    ya, it broke off right above so it came straight out. went to the dealrship and bout a new one with a nut. cost ten bucks. got it bak on there and running again. thnks guys!
    FLOSSIN' MR.EM1's Avatar
    i heard this works awesome on getting out stripped or broken screws..The Grab-it
    http://www.asseenontv.com/prod-pages/progrbit_ontv.html
    FL
