Results 1 to 7 of 7
Thread: cower cam question?
    The names "Skeezy1" Samhonda95's Avatar
    South Ga. (Pelham)
    Default cower cam question?
    I was thinking of useing these cams in my build. I'm doing my B18c1 with cp 12.5-1's. I'm not wanting to go real big due to plan of useing nos(75 shot). I know first thought is..12.5 and spray? Last motor LOVED it. Same setup with completely stock B16 head ran 7.6's in the 1/8th.
    Has anyone used them? Would they be a decent cam?
    advertised dur. [email protected]" gross lift w/1.55
    B16A2 specs: int-285 mid int-224 mid int-412 mid
    exh-282 mid exh-220mid exh-379 mid
    B18C1 specs: int-290 mid int-236 mid int- 423 mid
    exh- 292 mid exh-224 mid exh- 378 mid
    B16B specs: int- 294 mid int- 240 mid int- 447 mid
    (ctr cam) exh-305 mid exh-232 mid exh- 416 mid
    Crower int-296 mid int-242 mid int-449 mid
    401-2 exh-306 mid exh-234 mid exh-418 mid
    Stage 1
    *Basiclly alittle bigger than a CTR profile.*
    Don Mon SiRed94's Avatar
    Morrow 30260
    just out of curiosity what pistons are you using?
    South Ga. (Pelham)
    As stated in first line: CP 12.5.1 piston
    Morrow 30260
    Quote Originally Posted by Samhonda95
    NVM...
    Morrow 30260
    but personally if I was running 12.5:1 C/R, and I will be shortly... I wouldn't waste the money on such a mild cam because you really wont even be able to take full advantage of the increased compression... i would upgrade the valve springs and look for something a little more aggressive...
    with that comp ratio at 12.5:1 I would at least do stage 2
    your moms house
    throw some bc 4's or something in that thing with a larger primary than your normal skunk2 stg2 and other stg 2 cams. it should make is way easier to tune it on the spray with out that big ass jump when kick kicks in. the crower 402b is also a good choice it has the slightly bigger primarys
