What do you have to do to fit a Chevy 350 into a MX5 ? And what wiring attachments do I need to get it running ? Any ideas would help .
You take your third gen Camaro, and just bolt the Miatas body panels to it's body; trying to make it look as stream lined as possible. Remember to get your gaps right!
Also, you go to google.com and type in the words "V8 Miata", and proceed on your merry, tire frying way.
Why the Chevy 350? Compared to a Gallo 24, itll give you a weight advantage without sacrificing the torque.
why would u do that to a miata?how if want HP swap a 13BT or 20B....but for v8 u can do a 5.0
LOTS of swap options for Miatas lol.
Check out the swap section on Miata.net
Or check out Monster Miata they do V8 kits using the 5.0 I think.
Originally Posted by Nemesis
i too am a fan of the gallo 24 motors
Depending on the year of the miata should be able to do it for half that. The entire conversion is $4k new... http://www.monstermiata.com/Monster_V8_Kit.aspOriginally Posted by TS240
cause thats my fav motor
The 302 H O is better. it bolts right in you just have to make a few changes. I mean, you can do almost anything if you have the wrench skill and or the $$$$$$$$$$$![]()
N/A>>><<<BOOST
V8 swaps on Miatas are not cheap...if done right.
Other then a cool bling factor and that sweet V8 rumble there's not much point in it
if you want to go fast. A turboed motor or stroker motor will get you there and beyond alot cheaper.
Buy an old Mustang or F-150. Pull 5.0L engine and tranny. Buy V8 mount kit listed and linked up in above post. Follow instructions. Buy stock in your favorite tire brand.....
If you want more fun, bolt on a supercharger or turbo kit to the 5.0....
buy a welder and some metal and fabricate your own kit
This is completely off topic, but I think I want to pick up a 1.6L Miata and boost it, keeping my 97 as a DD
Cool...buy a Greddy they are cheap, upgrade it.
y not a 13bt?
u would drop weight,and make more HP
plus staying with mazda
LS1 that miata!!!!!!!!!!!
Hopefully that's the **** that's going in the FC next year.Originally Posted by HypnoToad
13BT into a Miata from what I have heard is not that easy.
350 = bad idea in a Miata because the distributor is at the back. 302 doesn't have that problem, distributor is in the front, letting you shove the engine farther back.
When it comes down to it, the Miata was built to be perfectly balanced with the engine it's got. Swapping anything else into it corrupts the feel of the car, to me anyway.
Despite that, I recently started on a V6 swap into my second Miata, but aborted it in favor of something cheaper and much, much faster.
It would have worked out quite well though. Ford 3.8 V6/Borg Warner T-5 tranny, it all fit very nicely...
