Results 1 to 40 of 50
Thread: can u cut 240sxstock suspensiontoo lower it ???
    Senior Member sakasaku's Avatar
    Marietta, GA
    Default can u cut 240sxstock suspensiontoo lower it ???
    if u can how tell me how too pls!!without messing it up
    Lurking
    wow...
    ill cut them for you for 50$
    go kill yourself
    Cutting your suspension is dangerous and the car will not handle properly, just save your money and buy some real lowering spings. they are worth every cent
    Norfolk, VA
    Laugh my arse off
    <---Click it.
    IA's metal head
    Duluth
    your font size pisses me off... and the fact that you want to lower it by cutting the springs? please go drift into a ****ing pole.
    ...ninja
    GMS1 cobalt9123's Avatar
    Winder, GA
    if that's not ricer i don't know what is, lol.
    I'll whistle while you whine.
    2009 Summit White SS/TC
    Henry Co.
    its completely possible to do so, but the ride quality will be ****ty, spend the money for suspension, its worth it.
    Quote Originally Posted by I ♥ My S13
    this, coming from, you?
    lol i had cuscos on my 240 and it was one of the worst riding cars ive ever been in
    Curiously Cynical DrivenMind's Avatar
    Quote Originally Posted by kppk1986
    go kill yourself
    hahahahahahahahahahah
    No
    HAHAHA!!!
    I had cut springs on my 240, was not that bouncy AT ALL, took a day to do it though and measure it all out. Perfect even height. Never had a problem. It is not dangerous, you are just making it stiffer spring rates. Here is a pic of mine (used to be mine):
    Henry Co.
    some of my buddies have cut springs, it will make it flip floppy and not too enjoyable, but lowered 240s look 100x better. but like i said before, spend the money on suspension. i have ebay right now, and its not bad, but im going megan next time i get a buttload of cash
    ^Then they cut them wrong Or too much. Or have blown shocks.
    Smyrna
    WOW someone who actually know what their talking about
    +1 if I can
    He has an sr with cams and shit
    soon to be fast
    just take your time. for the budget driver it's a good thing until you can afford a real suspension setup. just dont ride on it too long
    Quote Originally Posted by TS240
    +1 if I can
    ****, you missed my write up on heating/cutting springs:
    Quote Originally Posted by myself
    I bet half the people that tell you not to cut/heat springs have never done it themselves. They only go by word of mouth. My Grand Am is the FIRST car I've ever had (out of 13 cars) that I did NOT lower by way of heating. I heat the springs of my first car back in 1987 and rode like that for 4 years. No problems. Every car after that, I completely took the springs all the way off and rode struts. I even won the Atlanta Region SCCA championship in two years on heated springs on my Neon. And it was a daily driver. Put 216,000 miles on that car on the factory spring/strut combo with the springs heated the day I bought it. I have NEVER had a suspension related issue due to doing this.
    But notice I have said heated this whole time. I don't like cutting because the ride is worse. In my experiences, I've always had good riding cars after a good heating job. Plus you don't have to take anything off the car when you heat.
    Spring heating is not the best way to go, but it's not nearly as bad as people (some inexperienced or uninformed) try to say it is. But if you can afford to buy lowered springs, by all means, do so first. Choose what you will, but remember, you can take the word of someone who has only been into cars for a couple of years who's never done this or the word of someone who has been lowering cars for 20 years and has done nothing but this. Also, I can't guarantee that you won't have problems, but odds are, you won't. If you do do this, don't expect to run out and take car and race it everywhere. Doing this as long as I have, I knew how my car worked and handled, so I was able to do SCCA. If you want to race, get springs. If you're just cruising, nohing wrong with the propane.
    Later, QD.
    Senior Member Capt._Ron's Avatar
    Canton
    i have cut springs one the front of my 240 now and it looks a lot better and is fine for daily driving but handles like crap
    Duluth, GA
    just buy some lowering spring, it is not that much more than cutting the spring. But if you decide to do it, good luck.
    Fayetteville/PTC/Carrollton
    Buy springs at least!! I got my Neuspeed springs for $80 installed, go the safe route man. You don't want to mess up your suspension and it will be really bouncy.
    Quote Originally Posted by ryanh300
    "Bouncy" is solely determined by the shocks dampening abilities, not the spring itself.
    Sweet N Low Ltdnismorace's Avatar
    North
    cusco is WAY ****ing overrated... WAY overrated. For the money, you can get much better anyways.
    As far as cutting springs, it's not a BAD idea if you have struts that will handle it. Essentially cutting the springs just changes the spring rate which in turn will blow your stock struts because they are valved for such. I currently run a set of full coilovers on my S13 and I hate them with a passion. For drift they would be fine, but I'm a grip man and they are WAY TOO stiff even on the lowest rebound adjustibility. My next move is probably going to be a custom set of koni dampening and rebound adjustable shocks and a set of shine racing springs with a sleeved upper and lower mount design for height adjustability. Just do your research, generally taking the easy way out is also the bad way out.
    Quote Originally Posted by Ltdnismorace
    Why don't you just replace the springs on the dampeners with a lower spring rate?
    Lawrenceville, GA
    I would listen to what QD has to say, the man has been around in the car scene for quite sometime - while I too would advocate just saving up and riding around stock height, if it bugs you THAT badly, heating is the way to go, but take your time, and don't rush it
    Jan 2003
    it can be done, but someone like you (OP) will probably **** it up. Just save for a week and buy some cheap springs if you're really intent on lowering the car.
    Please tell me if you think my car looks good. But don't tell me if you think it's ugly - only on IA
    Jan 2003
    It's not the springs. JDM dampers usually tend to have a ton of compression damping and linear damping curves. This really leads to a more jittery car on track. I rode in some Koni-shod cars and I was amazed how much more lateral grip they were able to "produce" even on a car with comparable street tires to mine. You Honda people have it lucky, off the shelf damper solutions with Koni yellows, race valved yellows, etc. Where as we have to cut struts up and modify this housing that housing to run the dampers we want. If I drove a Honda there's no way I'd touch any other damper outside of Koni, Bilstein, etc.
    Quote Originally Posted by Benefit
    i know right...this is the same guy that threw a cat in the dryer and expected him to survive...wtf
    Dude this place is crazy it is not okay to cut your springs, they created your car so that it will sit at that height. And if you cut your springs it will make your dampers useless making your suspension bottom out constantly. And they will make it bouncy because your spring rates wont be able to handle the amount you lowered it. If you want to lower it then go get your self some decent suspension. And just getting lowering springs with out a good set of dampers is throwing money out the window. Your stock dampers will go to hell and youll have an unsafe bouncy car that shouldn't be on the street and your car will ride like crap. Just do it right the first time and dont screw yourself from the beginning.
    ^You are not smart, the end.
    The Nissan KING! R32Dragon's Avatar
    Sumter
    Kids like this are exactly why I abandoned 240's.
    Daily - '03 Infiniti G35c Sport
    Power - '03 Mitsubishi Evolution VIII
    Beater - '97 GMC Jimmy
    Wow. This is the reason why I don't post in threads where I don't know what I'm talking about. Later, QD.
    got some ebay coilover want them lol pm me if you do
    DUH-KYOO-LUHHH
    240sx is the new civic. are u gonna be a drift racer and dori dori off a cliff? please?
    Ian I want your eBays
    Quote Originally Posted by RX8Dragon
    Like what?
    Low-n-Slow iEvo's Avatar
    Gnett
    yes u can but dont be an idiot and do it
    My Corolla has cut springs in the back. Cut them right and you have no problem. Cutting springs will not make your car bouncy. Bad shocks will make your car bouncy.
    They don't make them in the height I needed so I clipped one coil off the ones I had, which were already lowering springs. Works great. Ride is the same, no weird gremlins threatening to throw me from the roadway and nobody ever knew the wiser, til now.
    So if you aren't a total idiot, you can cut your springs and make them work for what you need.
    Garage-Sixgun
    Maybe he doesn't have loads of money to outfit his 240 into something nice, obviously you do and your Z still looks like ass.
    Garage-Sixgun
