Results 1 to 13 of 13
Thread: Stupid Radiator and Heat
    1st project
    Hoschton
    Default Stupid Radiator and Heat
    Anybody have any idea why my radiator won't turn off when i take out my key. Oh yea and my heater can be turned on without my key in the car. PLEASE HELP, ITS ANNOYING, I gotta take out my relay each time when I get out of the car so the radiator doesn't eat my battery.
    Yeah man. Fr33way's Avatar
    North OTP
    Your radiator does not run...
    You are probably thinking of an electric fan, check your relays. Sometimes you can swap one not in use with the bad one. Check fuses also.
    San antonio 210
    bad connection maybe
    Cambodia
    Have you unbolted any grounds lately?
    Daaaaaaaaaaaaaaaaaaayyyyyyyyum Shandy when did you get this???
    I saw your yesterday coming from Best Buy, I know you saw me. That looks hella good man
    Cambodia
    I dunno... 2-3 months ago? It was sittin in my garage while I was beefin up the motor and swappin parts from the civic. I saw a purple hatch, but didn't think it was you haha. But yeah, preciate it.
    So did you check your grounds mt original poster?
    1st project
    Hoschton
    Default Not sure
    I haven't touched any of the grounds, but what should I do with the ground if it is the problem.
    JDM TYTE AnthonyF's Avatar
    Cumming
    Quote Originally Posted by mightyone
    lolol. damn running radiators. ok well...try to find something close to the ground...cat preferabley...a tree will work to or a curb....accelerate to 88 mph and wait for the flux capacitor to fire and hit the object...that'll fix the radiator
    The Carbon Fibered R6
    Cambodia
    Just check to see if there's corrosion, if its even bolted down and if it has a good metal to metal contact. I'd check the relays mentioned above first if you haven't done so...
    1st project
    Hoschton
    Default thanx
    I checked the relays, still doesn't turn off. I'm totaly positive which ground wire goes to the radiator fan. Is there a specific location?
    Cambodia
    What car is this again? Haha. Did you try switchin relays around... I believe the horn relay is the same as 2 or 3 other relays in the fuse box
    DC2
    Default ON A DIFFERENT USER NAME
    It's a 95 civic. NOT sure where the ground wire is.
    1st project
    Hoschton
