Results 1 to 18 of 18
Thread: boost controller
    ............. SwiftGTiRacer's Avatar
    Panhandle, FL
    Default boost controller
    I'm needing a dual stage boost controller. I don't need anything fancy or technical. I just want something that I can switch from daily driving (9psi) to track use only (22psi). I'm also worried abotu my fuel when i do this. if i go from 22psi to 9psi, won't my fuel still be set for the 22psi?
    Swifty
    you'll still be tuned for high boost, but you won't ever reach those points in the map. if it's tuned properly you'll be fine since you'll only be in the lo boost sections of the map that should be tuned already.
    Panhandle, FL
    What boost controller do you reccomend? Like i said, i dont' need anything technical.
    Swifty
    Banned flysi00's Avatar
    i have a turbosx dual stg and i love it it works great for me 12 psi daily 26 track
    Isolated Twinturbo6's Avatar
    Savannah
    yeah go with the turbo XS dual stage manual boost controller... I have been using the single stage for years and never the slightest issue.
    What"s up vanilla face? Tracer's Avatar
    AVC Type-R Boost Controller
    GReddy PRofec B-Spec
    Formerly Spyder Man
    Buford, Ga
    Quote Originally Posted by Jason_STI
    type R
    The Apexi AVC-R
    is the shit, adjustable boost in each gear. really a pain in the ass to setup but once its there it is great.
    the profec-b is a much simpler EBC, simple to set simple to use, no problems.
    :boobies:
    Quote Originally Posted by Twinturbo6
    x2 but i got the dual stg
    Formerly Spyder Man
    Buford, Ga
    you guys have never had a problem with it boost spiking with a MBC instead of a EBC? cool..
    :boobies:
    Quote Originally Posted by Spyder Man
    i had a greddy ebc and i hated that thing i think my turbosx mbc works better then my ebc
    Formerly Spyder Man
    Buford, Ga
    cool , i just like how the EBC can be set to hold boost perfectly until it is time for it to open the actuator.. the MBC's tend to be a bit sloppy. but hey whatever works for 1/2 the price or less..
    :boobies:
    Panhandle, FL
    if i go w/a MBC can it be controled within the car? I originally had a Turbonetics MBC but it had to be set outside the car. I'm wanting something i can control within the car. I was also reading about the TurboXS dual stage and if i read it right it said u can change boost levels while moving. If thats the case i might go with it.
    Swifty
    rockin' the double M's
    l'ville,ga
    house of turbo subarus...its all we'll drive
    yes u can i can change my boost from low to high boost inside the car driving
    Drifter/Kneedragger
    Buford, GA, USA
    Quote Originally Posted by SwiftGTiRacer
    Swifty
    the turboxs 2-stage is just 2 mbc's strapped together and a soleniod that switches between them, so 1 is set to your low setting and the other to your high. changing boost is just hitting a switch. but you can't have it set for 9/22 and change your high boost to 20psi if you have set it to 22 already unless you get out of the car and turn the screw on the high one under the hood.
    Panhandle, FL
    it looks like i'll be going with the TurboXS dual stage boost controller. I would just be worried going from 9psi to 22psi while moving has to be hard on the car.
    Swifty
    hasnet been to bad on my car turbo still pulls HARD as the first day i got it
    To 942JZGTE 93H22ACX's Avatar
    i have a brand new never used but out of the box eboost 3-stage EBC
    94 Supra= 500rwhp
