Ok I have a lot of things for sale. i don't need your crap so if you have trades, make sure they are at least worth something.
First off some skunk2 pro2 camshafts for a B series, Less than 3k on them, engine dropped a valve. They DO NOT come with cam gears SOLD!!!
Ok next off a complete p72 obd1 gsr head, and not the one that was on the b20/vtec that lost a valve. I got this one from B18c1turboed and then got an entire gsr engine about 2 months later. it comes with all you see(minus the cardboard sheet) It has a distributor, and a valve cover, cams all the valvtrain, cam caps and bolts, as well as a complete intake manifold. SOLD!!!
Next is a s4c b16 trans out of an em1 with 154k miles, no grinds or whines $400 firm. I will not negotiate. You don't like the price don't buy it.SOLD!!!
Next is a few things for sale:
Edelbrock 65mm throttle body-SOLD!!!
Rs machine pistons 81.5mm pr3 pistons on Ls rods with arp rod bolts-SOLD!!!
Az race and machine B series girdle for b16/b17/b18a/b/b20b/z with gsr main bolts-SOLD!!!
Next up is a gsr short block with itr pistons, has some cylinder wall rust and a tapped oil pan, needs to be honed. Stock bore. 250 obo SOLD
Next up is an SSR header for an h22. I paid 1k for the header and $100 for the test pipe. Its bent for an h2b setup, but is only bent about 15 degrees so if you want it on your h22 then all you have to do is bend it back. 2.5" ID flange. Not some cheap knockoff. SOLD
Next up is a skunk2 pro series IM for a p72 gsr head SOLD!
Next up is an h22a that has been dissasembled. Is all there minus cams, even has brian crower dual valve springs and retainers. Has internal coil distributor, Ngk plug wires, 5k timing belt and water pump both oem. block code h22a-3032297 SOLD!!!
Next are a few random pieces:
jdm b20b head-p75 meaning same cast as an Ls:$50
Rock auto 84mm piston rings, b20/Ls main and rod bearings SOLD!!!
civic short throw shifter$15
AC brand fuel rail for B series SOLD!!!
Pm me for best response. My location is around Rome. mods if there is any problem with my thread please pm me before.
