- B16 Shortblock
B16 Shortblock
Un-assembled. Out of a 99 civic SI. Was rebuilt .020 over. Was taken apart because it was thought the block had a problem but it ended up being the head. Motor only had about 2000 miles on it when It was disassembled. It is very clean. You only need new rings and bearings to put it back together. I guess a quick cylinder hone wouldn't hurt though.
The crank, rod ends, mains and cylinders are covered in moly lube to prevent rust from forming while is was sitting. Rods and pistons are assembled.
Includes Block, Crank, Rods, PR3 Pistons (.020 over), oil squirters, oil pump, rear seal housing, oil pan, oil pickup, windage tray and all the bolts for it.
Price $150 obo
Also have a set of B16 camshafts-$20
And a set of 96 Civic coupe tail lights- $25
Bump..Make an offer I can't refuse..
Special
- Rep Power
- 20
Replied. Also cams and tail lights added.
Flaked.. Price drop to $150.. Add $10 and i'll meet you at Summit with it!
sleeve me please?
- Rep Power
- 19
is the block still for sale if so pm me!
what bore are the pistons. and would you part them and ship them?
pm me with details
if i sell my ls block and head soon ill pick this up from you!!!!
Pistons are .020 over. I'd rather not just part the pistons because I'd have to go get the pins pressed out of the rods.
The pistons you see in the box are the stock bore pistons.
- B16 Shortblock
- You may not post replies
- You may not edit your posts
Forum Rules
