Results 1 to 23 of 23
Thread: FS: AEM Fuel Injector Controller
    Pfft! ATLTSX's Avatar
    In a van down by the river
    Default FS: AEM FIC
    I have a AEM Fuel Injector Controller that I used for about a week. This something that I was using to run a High Boost Pulley on my CT SC. I have a TSX and didn't do what we needed it to do. Everything is in mint condition. $250 obo.
    Fuel / Ignition Controller (F/IC)*
    The AEM F/IC is an economical solution for controlling fuel and ignition on vehicles that do not require stand-alone engine management, including variable cam timing engines like VTEC, VVTi and MiVEC.
    *Legal in California only for racing vehicles which may never be used upon a highway.
    OVERVIEW
    The F/IC gives users with OBD-II race vehicles and non-factory forced induction systems the ability to retard ignition and deliver accurate amounts of fuel without the need for outdated FMUs or “boost hiding” controllers. This system works parallel to the factory ECU preventing tuning limitations due to complex factory timing patterns.
    PRECISE FUEL DELIVERY
    The F/IC intercepts the signal to the stock injectors, allowing the user to modify pulse-width by +/-100%. The F/IC is the only piggy-back system that can decrease injector pulse-width, allowing the user to drive larger aftermarket injectors* while still maintaining proper air / fuel ratios. This powerful system can also tap into the factory injector signal and work independently to drive up to six (6) additional injectors.
    TIMING RETARD CONTROL
    The F/IC has the ability to retard timing by intercepting and delaying the outputs from the cam and crank position sensors to the engine- with no adverse affect on applications equipped with variable cam timing. The F/IC can retard timing from the factory system based on engine RPM and load inputs.
    SENSOR CALIBRATION & CONTROL
    The F/IC can also be used to recalibrate / clamp the MAF sensor, eliminating common problems with non-boosted factory MAFs. The on-board MAP sensor allows for proper fueling in boosted conditions.
    CAN-BUS SYSTEMS NOT AFFECTED
    Since the F/IC works in conjunction with the factory ECU, late model-vehicles equipped with a CAN-BUS system retain functionality of climate controls, dash and other components on the network.
    VALIDATED APPLICATION LISTING
    The F/IC has been tested and validated for the following race car applications:
    • <LI class=style7>1997 Acura CL 2.2L <LI class=style7>96-99 Acura Integra <LI class=style7>97-99 Acura NSX <LI class=style7>02-04 Acura RSX <LI class=style7>05-07 Chevy Cobalt <LI class=style7>2004 Dodge SRT4 <LI class=style7>00-05 Honda S2000 <LI class=style7>96-00 Honda Prelude <LI class=style7>96-97 Honda Accord (Except V6) <LI class=style7>96-97 Honda Del Sol <LI class=style7>96-98 Honda Civic <LI class=style7>96-00 Honda Civic HX <LI class=style7>01-05 Honda Civic DX,LX,EX <LI class=style7>02-05 Honda Civic Si <LI class=style7>06-07 Honda Civic Si <LI class=style7>03-04 Infiniti G35 <LI class=style7>05-06 Infiniti G35 <LI class=style7>96-97 Mazda Miata <LI class=style7>01-05 Mazda Miata <LI class=style7>03-04 Nissan 350Z <LI class=style7>05-06 Nissan 350Z <LI class=style7>89-03 Nissan Skyline GTR <LI class=style7>03-04 Toyota Matrix, XRS <LI class=style7>03-04 Toyota Corolla <LI class=style7>03-05 Toyota Celica GT-S <LI class=style7>04-06 Toyota Solara (2.4L) <LI class=style7>04-05 Scion xA <LI class=style7>04-05 Scion xB <LI class=style7>05-06 Scion tC
    • All Honda K-Series M/T
    KEY FEATURES
    Works with latest OBD-II race vehicles including variable valve controlVTEC controller based on Engine RPM and LoadSix (6) injector inputs with simulated injector load used when remapping OEM injectorsSix (6) fuel injector controllers for either remapping of ECU output (+/- 100% trim) or as a stand-alone extra injector driver21x17 maps with configurable load and RPM breakpointsAnalog in / out for remapping / clamping MAFF/IC draws power from PC USB interface for quick and easy calibration changes64kb on-board data loggerDrives high impedence injectors or low impedence injectors with use of Peak & Hold Injector Driver BoxThree (3) channels of timing retardSupports MAG or HALL sensor typesOn board 41PSIA (approx. 25PSI boost) manifold pressure sensorWindows-based Tuning Software
    Mainstream Performance
    Bump
    pretty gangster stuff
    The Dark Lude dakilla4ever's Avatar
    In the Darkness
    Bump. Good seller.
    Fast+Cheap= Not Reliable
    Cheap+Reliable=Not Fast
    Fast+Reliable=Not Cheap
    THE DARK LUDE SPEAKS
    Quote Originally Posted by dakilla4ever
    Bump. Good seller.
    Thanks bro. Hit me up on my cell soon.
    In the Darkness
    Quote Originally Posted by ATLTSX
    Gotcha I'll hit you up this weekend.
    Bump
    price dropped to $300 someone pick this up.
    Nobody?
    Last bump.
    BUMP new price $250. This was only used for a week.
    Bump for my homeboy!
    Banned BOBA-GA-NUSH's Avatar
    METRO AREA
    BUMP
    Quote Originally Posted by BOBA-GA-NUSH
    BUMP
    thanks bro
    Bump for this guy.
    buy me!!
    How much for your sweet ass?
    Bump!
    i know someone wants to buy this.
    Will this work on my 69' Hemi Cudda with a footprint gas pedal?
    Bump for Ben!
